12v Power Outlet Passenger Side Not Working
Kai Lover
Tampa, Fl
On my 2005 27 Islander I replaced the passenger side outlet with a new one. The connections are good. The Captain's side works perfectly. The fuse shows 12 v accessory--fuse is good. I assume this is the only fuse. What am I missing :?: ????
ElyseM
highlands, nj
i have a few fuse blocks. check all of the fuses you can find. wouldn't hurt to check the continuity of the actual socket to make sure it's good. ron
I would review the wiring diagram for the boat if you have or could obtain from GW Cust Serv. But before digging in too deep, I'd see if you can get to the back of the 12v outlet. Maybe a wire is loose or disconnected. If ok, chase back and check for voltage along the way.
Kai Lover
Tampa, Fl
Only fuses I see are under helm and in the t top box. Onlyh one for accesory is under helm. Where are anymore fuses located? Thanx for the help.
