2000 Grady Nav / Running Light replacement LED
gradywhite248
Looking for LED Nav light assy direct replacement units for the 2000 Voyager. I can seam to find any where. Not sure i want plastic? any help would be great
Viking88rd
This is what I used to replace old oem nav lights. They are Atwood. Ordered mine on Amazon, but available elsewhere also.
Reactions: gradywhite248
I think you lights are Perko side lights. There is a Perko LED version but I don't know if it is an exact macht to the mounting screw holes.
Here is a link
barclayrl
I replaced mine with the new perko. They are fantastic but not the same pattern. I was able to adjust them so no holes needed filled. Just had to buff the area good while the old was off before putting the new ones on
wrxhoon
Sydney Australia
If the lights are in good condition why not just replace the globes. That's what I did on my old boat.
imjus4u2nv
New York
I went with the 2 nautical miles ones, they are brite.
The Perkos are nice. Did them a few years ago. Bright and reliable. Replaced the mast light bulb with an LED too.
Replacing a lamp with a LED bulb for a mast light is OK but it is not a good idea to replace the nav light bulbs with white leds since it is possible that the colored lenses will block a lot of the led spectrum and reduce visibility
wrxhoon
Sydney Australia
Worked well on my old boat and they were brighter than the incandescent globes, new boat has factory fitted LEDS.
