246GT GRADY SEASTAR HAS NO BLEED NIPPLES
HAS ANYONE DEVISED A SOLUTION TO THIS PROBLEM? I NEED TO FINALLY CHANGE MY PISTON SEALS AND THE HC5340-42 DOEST HAVE BLEED NIPPLES OR ANY HOSE ATTACHMENT POINTS OTHER TAN AT THE HELM.
Aren't there bleeder plugs next to the hose fitting?
I believe those are the bleeder ports. They may be a bear to open. I am not sure what the correct procedure is to bleed without couplers.
