- Oct 12, 2017
- Manasquan Inlet NJ
- Website
- www.youtube.com
- Express 265
Another project to start. I need to start doing instead of starting....
I have done this before on another boat using pvc board. This time I can use existing plastic backer.
Used the Sailrite website. BTW, they have a good video for this coaming project.
Went with 2" dry foam. Its going to be thicker than the existing.
They were out of light grey that was on there (probably replaced years ago by PO) so I had to go with WHITE. Nothing on my faded boat matches the cream color.
I went with the channeled vinyl for looks. Unchanneled would be half the price.
I don't have a sewing machine so will not use mesh at bottom. Will put in some brass grommets for drainage/ventilation.
Bought a pneumatic stapler because I don't think I want to use my manual stapler for that many staples. Plus, it has bump trigger!
T50 MONEL staples. I have 3/8" and 1/4".
FYI, ONLY use MONEL staples. Stainless Steel will bleed rust.
Will use Loctite spray adhesive.
There are two spots at bends where I may need to sew so I don't have a wrinkle. We'll see how that plays out.
