305 Express water leak fixed
teaklejr
Fixed our water leak that was coming into the aft berth. That black box piece with the black corrugated tube is the bathroom vent and used to be the other way around. The black tube used to go into the bottom rear corner, when it rained or if we had a lot of spray from starboard side water would go passed the outside vent louvers and drip inside. Siliconed a nipple in and attached the clear hose to the cup holder drain. Just blasted it with a hose and it works perfect. Hopefully this makes sense.
Curious if anyone else with a bathroom vent with the louvered outside vent has had this problem if so this should fix the problem.
drbatts
CT
Out of curiosity where was the water accumulating before the fix?
PDX-Boats
Thanks for sharing. I'll have to look at mine.
Looks like a nice upgrade
Reactions: frankm
The 305 doesn't have a window, so a vent was installed. Makes sense.
