85 OVERNIGHTER PROJECT
cdwood
Seems like a lot of new Overnighter owners around recently. Maybe some of you guys might be interested. By my own admission bought this boat from some shmuck who knew she was in rough shape but failed to mention anything. All I knew was I wanted a GRADY, bought the first one I found in my price range. The rest is history.
Engine had a knock when I bought it, not being a motor guy, did'nt care, it ran.
Well, the engine went, not unexpectedly, after a couple seasons so before repowering (by now I had found GG) figured I better investigate the transom since there was so much read on it. Had it surveyed and it was reported to be ok, duh!!!!!
With the blown engine off this is what I found,
Transom had some serious bow to it and with the trim off visible cracks in the cap.
What to do now? Everybody I talked to said sell the boat to some shmuck that does'nt know any better. I'm already that shmuck so rather than let a guy put his family or friends in an unsafe boat I decided I was going to make her well again.
Well let's tear the skin off and see what we have.
WHOA, was'nt expecting that. Time to do some homework.
Note: had it not been for the resourses of GG at the time, I would never have taken on this project.
Alright, lets clean it up and see where we are.
Well maybe not so bad, Drilled into stringers, dry wood thank god.
OK so here we go, we're commited now, boats all cut up.
Research, research and more research. Finally a plan is in place.
Marine plywood, if sealed properly, is material of choice.
Next, West System Products only, no cheap shit here, can't be doing this again. Used 4 gallons of epoxy by the time we were done, ouch!
OK, first layer of plywood in place.
to be continued.
BobP
So much for surveyors.
You are not the only one.
I wonder what he would say if you confronted him now ?
A motor knock is never good.
Live and learn.
Doing the transom job yourself saves several grand, and it should please you to know the same Grady model new is +$60K. The depreciation in one year alone is more than this one cost you, probably, incl repairs.
cdwood
upgrades
Next layer of plywood in place.
Hope this never has to come apart again because I also used a box of 100 SS screws to lock the plywood sheets together.
Time to put the skin back on.
A lot of glass and fairing work to come.
Felt the next step (gelcoat) really required an experiencedhand for proper finished look. Again talked to ALOT of people before settling on a retired gentleman who wasn't looking to hit a homerun , just liked working with boats. For half the cost of the next lowest quote here is what he gave me.
He even did the bottom paint and put the rub rail back on with no change in original price. Not many boat shops work like that.
Just wanted to show here the new thru hulls, which I really liked compared to the originals.
Time to hang the engine but running out of weather. Working outside thru a Jersey winternot an option. Can't afford to rent a place. Only one option left, my garage. Took some measurements. Without the motor and the windshield off this just might work.
Damn, I'm all set. Got everything I need, heat, my tools and something no garage should be without.
More to come on how I spent that winter.
cdwood
transom
Bread, had an engine rebuilt by my local Merc guy.
It's an 01 carbed 150 with new head. Fully rebuilt from carbs to lower unit.
Strike, wife enjoys the boat as much as anybody so got no complaints there.
ghcpa9
wow, awsome job!
out of curiosity, roughly how much would that transom rebuild cost if you hired someone?
cdwood
Easily a couple grand but really never considered letting someone else do it. Figured this would be a good way to learn stuff I wanted to know anyway.
gw204
Looks great! Nice job! :)
My only suggestion is to next time...if there is a next time...scarf and stagger your joints in the core. Scarfing makes the joint stronger and staggering offsets the joints.
cdwood
GW, can you elaborate on scarf and stagger?
NEM, there was only room for the thinnest layer of matt between the sheets. Had to have the outer layer planned off by an 1/8" just to make skin align properly.
richie rich
CD, what he is referring to is the 2 layers of wood should not have the same cut joints right on top of the next. If you cut 2 vertical joints on each side of the transom on sheet one, you should then maybe cut the long way on the next layer or just move them in 6 inches so the seams never create a weak point. The scarf is basically an angled or mitered joint between your cut pieces instead of a flat or butt joint....the stagger and scarf help reduce stress points at any joint.
You can use a layer of matt between the sheets but it totally unescessary. Actually, a thickend mix of epoxy and wood flour works best as it will penetrate the wood and the joint will be stronger than the wood ply itself. Most builders of wooden boats make they're layers and fillets this way.
One question CD....I see you left about an inch of original glass around the edge and then glassed in the original skin so only that small seam has new glass on the outside. Why didn't you just put fresh layers of 1700 or 1708 on the outside for maximum bond and strength? Was it simply a cosmetic issue, ie, the gel coat work afterward? I would think new outer glass would be a bit stronger, albeit a lot more finish work...either way....it came out fantastic...you got 20+ years left on that boat
cdwood
Ok, just wanted to clarify. If you look closely at the pics of both sheets you can see that there is a 4 inch difference in the cuts and they were cut at a 45 degree angle. Will try to post some better pics.
A close look at this shot shows the second sheet cuts with the first sheets cuts penciled in.
Here are shots of the actual cuts.
Focus is not real good on these shots, but please look close. Is this what you meant?
Great Job! looks like new! - Mine does not appear to be as warped but I need to get in there for a godd look. I took the motor off the boat yesterday, the wetness/damage seems to be mostly on the right side and probably due partly to the fish finder and speeedo wheel which was not properly sealed up and of course the factory seem at the cap. I think I am going to cut the cap off today as well to get a better look in there. I am still going ahead with the alum plates for now and plan to start cutting them today as well.
how do you fasten the plywood on the back side? Is it bonded to the inner glass wall?
cdwood
Merc, yes you do want as much bond there as you can get, make the epoxy very thick and don't be stingy. You want to see it squeeze out around all your outside edges.
Top
