Hi, just realized as I put my 9.9 high thrust 4 stroke kicker on the bracket that the hydraulic cylinder wasn't working. Took it off and it slides easily, I can see the seal is bad. Called a local hydraulic repair shop, won't touch it because of it's age. It's a OMC System Matched Auxiliary Motor Bracket, 125 lbs. Max.
Any idea if I can get a replacement? Says it's obsolete on iBoats...
Probably just bite the bullet and get a new bracket, but hoping for advice.
Thanks,
Don
Thanks,
Don
