- Jun 4, 2020
- Age
- 38
- Seattle area
- Seafarer
I'm not 100% sure that both batteries have gone bad at the same time, but I figured that if I'm going to replace one and I'm uncertain of the age of the other, that for an extra $80 it's a bit more peace of mind. The jump pack was charged up all the way but the motor went from starting up on Saturday to not being able to start on Sunday, which to me makes it sound like the battery gave up its ghost over those two days. My thought process would be that if it was a charging system issue and not an issue with the battery or batteries, would be that they in theory shouldn't be completely drained in a day and then having them powered off overnight. I suppose it's true that there could be more than one issue and that the batteries could be on their way out as well as having a charging system issue. That being said, with buying the boat used and not having any confirmed dates as to when the batteries were last purchased or replaced, that would be my first train of thought since it was a drastic thing and essentially happened overnight. If it was something where it took a few weekends or whatnot, then yeah maybe more of an alternator or charging system culprit. Lastly, if the batteries were still decent, I'd think the fully charged jump pack should start them right up even if they were a bit on the lower side. I had something very similar with my daily driver vehicle a few months back where I went out to start it one morning and it didn't want to start at all. Hooked up the fully charged jump pack to it, still nothing, and to where I had to use the jump pack as well as add a charger to it to finally get it to turn over and start. I ended up replacing that battery, which was 7 years old, and I'm thinking it sounds like a pretty similar story with my Grady to what happened there.It is odd that both batteries seem to be bad at once. No? For sure they are likely due for replacement but you may have a charging system problem. in my (automotive, not marine), a low voltage indicator with a running engine is a charging system issue. Not sure what gauge package you had but did the engine gauge (not the GPS) indicate low voltage while running?
When you went to start with the jump pack, I presume it was completely charged. Did you let the jump pack connect to the battery for a bit, like 10 minutes?
I don’t know how far you go to haul the boat out, it should start and run on new batteries but will discharge them. Would hate for you to smoke a new battery. Perhaps if close by you can get a tow to haul out and do some additional diagnosis and battery replacement in a more convenient location?
