add tilt to helm steering wheel?
G
gradydaniele
Guest
currently have a 250 yamaha outboard equipped with seadstar Hydraulic steering.
im looking to add tilt to the steering wheel. does anyone here know if I can buy a tilt part to add to the steering colum or do I need to buy a whole new steering system equipped with steeribg wheel tilt?
Dan
artodea
Boston Northshore
You'll need to replace the helm pump and then bleed the system. The tilt helm may require a different hole in the dash or at least an adapter to fit, depending on your current setup. The steering wheel should fit on the new helm.
to be honest, prob much more work and expense than it is worth. you only get a couple of additional positions.
