Anyone ever shorten the factory battery cables on a Honda 150?
Recoil Rob
CT Coast
What size wire are they in the black rubber harness, #2AWG or #4 AWG? Like to know before I cut.
Recoil Rob
CT Coast
There's not a lot of room in the hatch and I don't need 6 feet of cable for a 1ft run.
The current lug is stamped 610 but the wire is at least a 4 if not a 2
That cable is most likely not a main battery cable. It is something else.
The 610 stamp means it is a 6 gauge wire on a #10 bolt stud
Recoil Rob
CT Coast
It's the main battery cable, it came off the negative battery terminal, it fits a 3/8" stud and the cable, along with it's twin for the positive, lead into the engine harness.
Recoil Rob
CT Coast
10mm (0.393") translates to between 00 and 000 wire, not that.
Make sure you can replicate the crimp. You can create a lot of problems (now and down the road) if you cannot. Sometimes it is better to leave alone like the manufacturer did. Just sayn...
Recoil Rob
CT Coast
I have crimpers for hex and square crimps, I'm set.
Gonna cut it in a few days. will report back.
A 1 ft run doesn't get you very far. How can the motor connection be only 1 ft from the battery terminal? Is that cable the only one bolted to the battery terminal?
You did say the motor is a 150 horse didn't you?
