- Sep 1, 2013
- Allentown, PA & Friendship, ME
- Offshore
I'm recoring the floor of the Grady and I thought I would try something different for the floor hatch. Given that it's easy enough to rectify, either now or even when it's in the water, I thought it might be fun to try something that hasn't (to my knowledge) been used before. There are obviously foam coring materials available (Divinycell, for example) so the idea of using foam is not at all new. What I'm going to experiment with is the inexpensive pink/purple foam-board insulation that you can get at Home Depot. I've got some leftover pieces of 3/4" board that I'm experimenting with right now. The picture below is of an unaltered piece of foam and one that I (very) quickly put a layer of glass on the top and bottom with epoxy resin.
The amount that it stiffened up is amazing. I'm going to do some weight tests to help quantify this. The only thing that concerns me a little bit is that, while the epoxy seems to bond extremely well with the foam board it does not soak in very far. Meaning, if I pull hard enough, I can rip the layer of fiberglass off the foam. I'm going to try using a star-wheel tool and poke a whole bunch of holes in the foam board and see if that makes a difference. Ultimately, I don't know if this will pose a problem or not since everything will be completely encapsulated with fiberglass. I'm open to opinions and discussions on this!
