- Oct 12, 2017
- Manasquan Inlet NJ
- Website
- www.youtube.com
- Express 265
Been juggling projects desperately trying to complete before scheduled launch...
Got this one done. Tank hatch was a little wet and glass came loose from edge. debated doing a partial repair but when I got into it I didn't stop.
I had a nearly full big can of West epoxy and some glass lying around. Turned out I needed another $100 can....and hardener... I should have used polyester resin but those West pumps are so easy...
Taking guesses on before and after weight of the hatch. Closest wins 10,000 Non-redeemable points
I tapered the outside edges of wood blocks 45 deg and dipped the glass down
then filled with thickened epoxy
Wood is 1/2" AC exterior pine. Not what I wanted but it was a reaaly good board...clear on both sides. Had a couple voids but not bad.
Can't find any "Marine grade" AB exterior douglas fir.
chopped strand mat then "buttered" wood squeezed down then gaps filled then chopped strand mat then some tabs of chopped strand mat then some tabs of 1708 and some old leftover light glass cloth
