M Mr.crab Well-Known Member Joined Dec 8, 2015 Messages 161 Reaction score 44 Points 28 Location California Dec 28, 2019 #1 Works pretty good, but not perfect Attachments E86305B7-7F73-4B6B-8A91-CD6B4311DCF9.jpeg 1.3 MB · Views: 62
M mleads310 Well-Known Member Joined Apr 6, 2016 Messages 271 Reaction score 40 Points 28 Location Brooklyn NY Model Sailfish Dec 28, 2019 #2 What model are those and where did you buy them?
M Mr.crab Well-Known Member Joined Dec 8, 2015 Messages 161 Reaction score 44 Points 28 Location California Dec 29, 2019 #3 18-AD1 they are 12 volt 150watts on Amazon , I turn them on first then get everything else ready .
Fishtales Well-Known Member Joined Jan 31, 2005 Messages 7,736 Reaction score 1,203 Points 113 Dec 31, 2019 #4 Good idea. May look into but go with a Velcro quick attach as I wouldn't want them there all the time.
S seasick Well-Known Member Joined Aug 19, 2008 Messages 9,171 Reaction score 1,319 Points 113 Location NYC Dec 31, 2019 #5 if they do pull 150 watts, the two together draw 25 amps. That is a fairly significant battery draw.
D DennisG01 GreatGrady Captain Joined Sep 1, 2013 Messages 6,865 Reaction score 1,218 Points 113 Location Allentown, PA & Friendship, ME Model Offshore Dec 31, 2019 #6 That's a nice, easy solution to an annoying problem. seasick said: if they do pull 150 watts, the two together draw 25 amps. That is a fairly significant battery draw. Click to expand... Along with that... is the wiring from the fuse block to the double outlet the proper size? Don't want to risk a fire.
M Mr.crab Well-Known Member Joined Dec 8, 2015 Messages 161 Reaction score 44 Points 28 Location California Jan 1, 2020 #7 The wiring is to the original block under the helm , with 4’ of 10 gauge wire and 30 amp inline fuse.Added a lot of equipment to this boat, didn’t care how Grady wired boats back then so ran new separate feeders from battery banks.
M Mr.crab Well-Known Member Joined Dec 8, 2015 Messages 161 Reaction score 44 Points 28 Location California Jan 1, 2020 #8 Also only used them when motors are running, because of the large draw. Also have six batteries onboard.
