- Sep 1, 2013
- Allentown, PA & Friendship, ME
- Offshore
On another forum, a thread popped up about a boat that started sinking due to a broken (plastic) thru-hull. The thru-hull was above the waterline, but not by much. Once some water got inside, it weighed the boat down enough where things started to get worse and worse. The colder couple (who, at that time didn't know why they were sinking) on the boat apparently got the boat into a slip, late at night, and dockmates where able to find the issue and plugged the hole. Obviously, there's a lesson here to maintain your thru-hulls, but in the event of an emergency, whether yours or a fellow boater's, carrying some (inexpensive) safety equipment can, quite literally, be a "boat saver". Below are some examples that I'd thought I'd pass along. Feel free to add anything you've found, as well. As the saying goes - better to have it and not need it, than need it and not have it...
-- Wooden emergency plug kit (bungs). I don't personally have these, but they seem to be popular.
-- TruPlug https://truplug.com/ I do have a couple of these and I'm sure they would work very well - especially for odd shaped holes/gashes.
-- A toilet "wax ring". I carry one of these, too. If you've ever changed a toilet bowl, I'm sure you can imagine how well it would "smoosh" into a hole.
-- Rescue Tape https://www.rescuetape.com/ I also carry this onboard for emergency hose repair. I haven't used it in on the boat, but I have used it for various things around the house and it is quite interesting as once you stretch it, it sort of glues to itself.
And, one last thing... keep in mind that beaching the boat is always an option.
