fiberglass chip fix
captainmichael
Has anyone used "MagicEzy 9 Second Chip Fix" for small chips? If so can you tell me how it turned out and what was the best color match.
Thanks!
I've used MarineTex and GW colored gelcoat with good results. Never the above though.
Caburke1
St. Petersburg, FL
I've used it and it worked great. I'm sorry but I don't remember the exact color, i think it was almond. If you dig around with Google, you'll find a reference to the Grady color. That's what I did.
Harpoon
Mix color matched gelcoat into a paste with cabosil.... it works dam good.
Reactions: ScottyCee
igblack87
ScottyCee
Samish Island, WA
Mix color matched gelcoat into a paste with cabosil.... it works damn good.
That's what I've been using. I have found that it takes 2 applications to build up enough to be flush (I'll bet there's a way around this). I've been using a little bit of surfacing agent in the mix too, and then razor scrape, wet sand, rub, polish. I have a can of the factory gel from my year and it matches pretty well.
My smooth surfaces are coming out great. The textured ones only so-so...
are you guys talking about the gel coat or the OP's question on Magic Ezy 9?
