Garmin GPS fuse on 25 Coastal Explorer
TSH
Coastal Explorer 251
GPS unit suddenly died. Searching for location of fuse.
Fuses are always (should be) near the power source. Locate your fuse block - it'll either be "in" the fuse block or it will be an inline fuse near the fuse block.
I didn't install that Garmin, though... so it ultimately depends on who installed it. Fuse blocks are often behind/under the dash.
wspitler
Inglis, FL
Garmin usually has an in-line fuse in its power supply cord, not too far from where it connects to Power. That will be there unless an outfitter substituted a fuse of similar capacity on a panel or another place.
Put a volt meter on the connector at the unit. See if the unit died or no power to the unit. As WSpliter said usually a inline fuse but could have moved to a panel or fuse block.
