Grady-White Parts?
GulfSea
Florida Panhandle
Just got my 228 a month ago and need a Bracket Drain Plug (plastic with seal). I also need an extra garboard drain plug for a back up. Is there an online source to order from? The nearest dealer is about 45 miles away.
Thanks, Steve
Curmudgeon
NC/GA
Both those parts are pretty generic and not specific to GW. Check out the usual online suspects for marine hardware.
For what it's worth, I got tired of fooling with the plastic bracket drain and replaced it with a standard garboard style ... :wink:
ElyseM
highlands, nj
if it's a gil bracket you can go right to them. that's what i did. bought a couple for spares. i filled the hole in the "nut' with 5200 for extra strength. at the end of every season i would open it, and re-grease it. don't over-tighten; finger tight only. i'm not sure you want to use a bronze garboard plug in an aluminum bracket.
you can get the garboard plug anywhere. ron
Parthery
Atlanta, GA
The Garboard plugs are available in Wal-Mart....about $3 apiece.
GulfSea
Florida Panhandle
Ok, I got the garboard plug but still don't know where to go for the plastic plug on the bracket. If there's a link, number or address anyone can provide, I'll go that route. Thanks for the heads up on the garboard plug.
ElyseM
highlands, nj
like i said, if it's Gil, give them a call. they have a parts dept. ron
