Head for 225
BrooklynJoe
Baltimore Maryland
Tournament 225
I saw this info on this forum before but I can’t find it now.
I have a 2006 Tournament 225 and I need to replace the existing head:: the existing head looks like a porti potty but it has the deck pump out and Macerator feature.
Looking for vendor and part number if possible.
Joe
Halfhitch
Venice, Florida
Joe, You probably have the Sealand 964MSD. There is a 965MSD and the only difference the 965 has a taller tank. You are limited on head room in your boat so I would guess you have the 964. Here is the parts list for both. Sealand has been bought by Dometic. Many parts are available on Amazon and ebay and many RV dealers.
To double check, pull it out and check the tag.
What's wrong? Those things are usually pretty indestructible... unless you'e been rough with it :)
BrooklynJoe
Baltimore Maryland
Tournament 225
Thank you—-
I am not the original owner… some time over the years the bowl itself cracked.. don’t know how bit it’s there…
thanks again
Joe
Halfhitch
Venice, Florida
Thank you—-
thanks again
Joe
WOW! I know they are known as a Thunder Mug, but to crack that bowl must have been an epic event.:)
Part #6 on the parts list.
Halfhitch
Venice, Florida
Most common problem is the #7 latch assembly breaks.
Yes, and a few years ago, you could order just that number. Since Dometic bought the outfit you have to order a "kit" to get those latches and that kit is a big portion of a complete unit cost. Thanks Dometic.
