help with parts manufacturer
devildogdad
I have a Marlin 300 and need a part. It is the twist off deck plate that is used to access the pull rods for the seacocks. It is OD 8 inch, ID 7 inch. I have looked and looked but can not find an exact match. Nothing is imprinted on the plastic itself Thanks
Try Beckson Marine. They make the screw in and pop out versions for GW.
eppem
Trumbull, CT
Second that, they are around the corner from my office and nice group. Ask for Steve, tell him the guy that just returned the black cupholder sent you.
devildogdad
Beckson does not list an 8 inch twist out on their website
ElyseM
highlands, nj
if it is oem, call GW and they will tell you the mfg. also, make sure that you are comparing the correct dimension. good luck, ron
journeyman
Gloucester, MA
They do, but the outside Dia is 10", and the inside Dia is 8.5". Look near the bottom.
http://www.beckson.com/screwout.html
I just replaced the pry out deck plates in the transom area with Beckson 6" twist outs (DP64-N). The outside Dia is 8", inside Dia 6", hole Dia 6.5". They fit perfect, even the screw holes.
devildogdad
according to GW the part is no longer made. so I need to figure out how to replace it.
