Help with Wiper Blade that has the attachment that connects to the arm
wadeatl
I am looking for help with finding a replacement wiper for my 2007 Tournament 275. I have read that the Anco 52-16 is common. My concern is all of the pictures I see has just a small nut, bolt and plate with it.
My wiper actually has a broken connector that seems to go to pressed shaft (not a bolt and nut).
Or... get a new arm - one with a standard J-hook - and you can get a replacement blade at any auto parts store anywhere. Look at the tag on your motor for the manufacturer, but there's a good chance it's a standard size. Try AM Equipment.
This is older info but may help. I was getting mine from NAPA. Windshield wiper blades. NAPA 60-1870 arm and blade. $9.99. Blade only 60-1805 $5.99.
Also Amazon for AFI 33014A arm and AFI 3101888 blades.
As Dennis said you should be able to pop the arms off and go to a conventional ANCO arm/wiper.
Solved the problem completely last year. Removed my wipers completely! I may try treating with StarBrite ViewGuard - specifically designed for clear plastic windows.
wadeatl
Thanks guys .. I went ahead and ordered the new arm ( Marinco 33014A) and a 16" Marinco Blade.
