- Sep 1, 2013
- Allentown, PA & Friendship, ME
- Offshore
Sounds like a silly question, but how do you do it? I looked into buying a plastic 55-gallon drum ($10-$20 on Craigslist). But, if I am correct, a drum is 24" in diameter and the length of my anti-ventilation plate is longer than that. Will the drum stretch/elongate enough to fit the lower unit in? Those of you with large OB's, how do you do it? I can, of course, continue to run it on muffs, but I'd like to get the backpressure on the hub for smoother running.
