- Mar 1, 2006
- Berea, KY/Cross, SC
- Seafarer
trackah said:Hi,
Does anyone have the part # for the LED anchor light? Also does it use the same screw holes as the oem part? same question for the port and starboard running lights same screw holes?
The Attwood anchor light I went with is a 5530-24A7, 24" pole. Taller than original, but figured if I ever put radar up there, it will clear without having to replace again. Different mounting holes, but I'm having my hardtop redone, filling in all holes and starting over with placement of antennas and such.
Haven't changed my nav lights out yet, boat is at shop right now. Can't answer about the hole pattern on those. Smokey just changed his out, maybe he'll chime in on hole pattern.
