- Oct 16, 2007
- Age
- 69
- Cape May, NJ
- Islander
I have a pair of 2006 Yamaha F150's with 2,100 hours. I wanted to ask if anyone has run a pair to end-of-life and what their experience was. Do they just get tired? Or do they grenade at some point? Right now the engines still perform like new. Only interested in comments from members with first hand experience - spare me from the research or rumor reply.
My engines have been well maintained. Yamaha oil and filters every 100 hours. New fuel filters every season. Mostly REC90 ethanol free fuel. Clean under cowling - no leaks or salt. I have not done a compression check but no smoke. Plugs changed every other year - they look new.
My mechanic said that ring problems are the most common problem with high hour engines. He recommends Ring-Free but I haven't been using it. Also I never shut the engine down the whole time I'm fishing. They are my "generator". Idling isn't the best thing for them. My mechanic says run them hard to blow out carbon when running in. I run them up a bit occasionally to 4800/5000 RPM's but general run in the 4000/4500 RPM range. Can cruise all day at 27 knots depending on sea conditions. 4-blade props gave me great mid-range performance that's easier on the motors.
Let me know your experience with the F150's.
