Looking for nav light - Freedom 255.
Capt Bill
First State
This new-to-me 2012 Freedom 255 has a dead nav light. I removed it today, and measured the voltage at the light, and it was 12.8V, so the LED is burned out. Port side works great, but I may replace them both, when I find the source.
And that leads me to my question; anyone here know the brand name (it's nowhere to be found on the fixture), or have a source for same look and footprint? I would like to replace it with one that mounts to the same mounting holes, and has the OEM look. Here's a photo.
Reactions: Capt Bill
The ebay link had more than 10 pairs. If there is more than one LED in the fixture, I would check my connections at the plug. They don't usually all burn out at once.
Capt Bill
First State
The LED matrix is sealed in plastic, with a moulded in Fresnal lens. Voltage to the lamp assembly is correct, and connector pins clean.
I placed an order at the ebay link you provided (thanks again), and I couldn't put it in the cart at first. Reason is the seller is away, and shipping will be delayed. When I agreed to that, it let me place the order.
I did find the same Atwood lights here, Atwood navigation lights, but they don't include the connector, and there is $10 flat rate shipping, so I decided to get the one with the connector.
