Marlin Boarding Ladder
ttles714
NJ
So I screwed up the boarding ladder on my 2007 Marlin300. I am trying to figure out how to access the mounting bolts without drilling an access hole. Any Ideas? Anyone done this ? Best location if I need to drill ?? Ladder is located on starboard side.
I'm guessing that will be a horror show. If you have to drill one, investigate one on the area infront of the ladder. It's a horizontal surface which isn't optimal, but if you pick the right location, you can likely get at the thru hole for the scupper drains. You'll need that access to change the drain hoses when they fail. Might be able to get access to both the ladder and the thru holes with one hole.
