ghcpa9 said:
I have a 1997 yamaha v6 175 2-stroke outboard that stays in the up position. It's not the manual latch that keeps it up, I checked that already. I'm getting electricity, the motor sounds fine when you hit either the up or down switch. Does it sound like hydraulic fluid issue?
If you hear the tilt motor running both when trying to trim up and down, it isn't the switch or a solenoid.
The piston could be stuck but it is unlikely that all three pistons are stuck, so if none move, its either a valve issue or a fluid issue or even a bad pump. Check the fluid level but engage the manual stops first. The next step is to open the manual overide valve and see if you can muscle the motor down. be careful there also and keep clear of the tail just in case it decides to quickly drop.
