Power steering question
Ozz043
G-Day All
I have a 1999 Marlin and lock to lock is a ridiculous number of turns...I haven't counted, maybe 10-12 ?
Is this normal ? I've tried purging any air out but there doesn't seem to be any ?
Your thoughts would be appreciated, thanks
seems excessive, but I have never counted. will get you some info.
Meanwhile
Warren, OR
My 2007 is 7 or 8 turns lock to lock. I did find the number online once but it depends on your helm and cylinders, one or two station. I think Google may be able to find the expected turns.
checked today. 7-8 here as well.
Tucker
Port Deposit, Maryland
I think you're bypassing at the wheel and it sounds like you may be in for a pump rebuild kit. Not too bad of a job, so I understand, I've never had to do it. There's a real easy way to remove the wheel; do a search and if no luck get back to us. I had a similar situation but not as bad as you. I flushed all my fluid, rebuild the steering ram, it was weeping just a little, and now it works perfect. Instead of the Sea Star fluid, I used aviation hydraulic fluid; it's even recommended in the manual. MUCH cheaper and it's red so any leak is easy to spot. Never could figure out why Sea Star used clear fluid.
The Sea Star guy is a regular on THT and he's real helpful. Might want to jump over there and PM him. All manuals are available on their web site and they are real easy to work with. Have the brackets holding the ram on your sbt motor ever been removed and greased?
Another route to go is to loose those OX66's and get a pair of those new Rudes with internal steering :mrgreen:
Ozz043
Thanks Tucker
I've counted and its nearly 9 turns lock to lock...which seems excessive...I'd think 5 would be suitable ?
I am on THT so will post and see how that goes. Cheers
bayrat
long island, new york
Ozz043 said:
Thanks Tucker
If you go on the Seastar website , they list the different units and number of turns lock to lock for each.Check your model number and then see what your lock to lock is listed at. I saw only 3 and the most turns was 5. Mine turns 5 1/2 and the tech says that indicates air. I also have power steering and apparently you have bleed that pump separately.
Ozz043
Guy's
I can't seem to locate any power assist pump...only the steering wheel...would this be normal for a 1999 model ? The manual doesn't mention any other pump..
Ozz043
Guys
I found the specs in the manual, for twin engine installation
Seastar 1.7, 9.2 turns
Seastar 2.4, 6.5 turns
Seastar pro 2.0, 7.8 turns
Now I just need to find out which one I have, I'm guessing it's the 1.7
Cheers
bayrat
Ozz043 said:
Guys
Cheers
I think that would be listed on the helm pump itself.
bayrat
Ozz043 said:
Guy's
In your original post you mentioned "power steering". I took that to mean you had power assist...did you mean to say hydraulic steering? If you had power assist there would be a line from your helm pump to a secondary pump and then it would continue back to your steering cylinder. Hope that clears it up.
Ozz043
Um yes must clarify ...hydrolic steering... Sorry I had my terminology incorrect.
I will check the helm next visit for any info on model.
