- Oct 12, 2017
- Manasquan Inlet NJ
- Website
- www.youtube.com
- Express 265
Bought this to install LAST season and never got to it.
Finally got done...almost...needs cleanup.
6 gauge safety (red/yellow) duplex run from Port Start battery switch, 25A breaker, fed thru port side pvc tubes to the anchor locker.
Foot switch and a relay. This is a one direction capstan.
I may also eventually add a dashboard momentary ON switch to the relay utilizing the Grady 10gauge wires that are there. That would allow the captain to run the capstan if its easier than having the mate stand on the switch while feeding rode down into the locker.
I widened the opening to the locker to make it easier the feed line down. I will never hang an anchor inside the locker.
Added a Sampson post too.
We are contorting ourselves to wire the relay and get nuts and connectors on and secure wire out of the way of the anchor rode. So we have it half assed wired in the bow locker.
Then I'm sitting in the cabin drinking a beer and I realize we should mount the relay in a plastic electrical panel with a door INSIDE the cabin on the fwd bulkhead.
