- Feb 28, 2005
- West Palm Beach, FL
- Sailfish
Considering pulling out the 12v-only fridge and putting a 6,000 - 7,000 btu AC unit in its place. Looking to experienced brain trust here as to what challenges to expect.
Boat is an 2007 Sailfish. Fridge is an Isotherm Model 1049BA1CL0000. It works fine and appears to be in good shape, but I have no use for it. Boat stays on a storage rack, so no option of staying plugged in.
From what I can tell, there seems to be sufficient space for a small AC unit.
I'm assuming it will not be easy to run wires from the boat's control panel to the AC. If that proves problematic, I either sacrifice or tap into the 110v outlet on the forward edge of the Corian counter top. Or use those outlet wires as a 'pull-through' if I'm certain the two new sets of wires (one set for the outlet, one set for the AC) will make it through! My electrical prowess is that I can usually tell the positive from the negative terminal of a battery. This should be fun.
For the seawater pump, my intent is to sacrifice the overboard discharge through-hull just behind the aft berth. If I follow the plumbing hoses correctly, this through-hull is separate from the pick-up for the seawater input for the head. However, it doesn't look like this seacock has ever moved, nor has any intention of moving. As a retired marine biologist, I could never use the overboard discharge anyway.
I'm hoping that the same discharge for the sink can be used for the cooling water discharge for the AC.
The duct work, I'm hoping, shouldn't be too bad. The intake screen gets built into the new door covering the space. At least one cool air outlet should be able to exit facing the port side of the V-berth. Maybe another outlet can work its way beneath the steps and cool the aft berth.
The trade off in weight seems near enough to even.
So, what problems am I likely to encounter? I'm certain this will not be as simple as I've written it out. Any fatal flaws?
Tx, Rob
Tx, Rob
