SeaStar question
Pighunter
After waiting a year and a half for a Panther kicker steering rod that never came, I'm trying to build my own. I made stainless steel brackets for both motors. The problem with the main motor a OX225 is finding a place to mount a bracket. So can I put a U-bolt around the Seastar without damaging it.
Pighunter
FYI. i've used these way back when they first came around. https://ezsteer.com/
worked great. might want to look into them. good luck, ron
Thanks but that's what I'm replacing, this is my third boat with a EZ steer system and I have had nothing but problems with all three systems. I'm going with a solid 1/2" stainless steel rod mounted on the front.
Chessie246G
Maryland
I would not clamp to the hydraulic ram. I'm not sure why you want/need to, It needs to be attached to the piston rod (the shiny one) as it moves with the engine left and right.
Pighunter
The housing is what moves right and left.
ElyseM
highlands, nj
fyi, the arm is intended to slide within the ez steer in order to account for the turning arc. very important to follow installation instructions. like i said, i used them way way back and maybe the product has deteriorated. good luck, ron
Reactions: Pighunter
Chessie246G
Maryland
I guess I didn't think it through correctly. LOL Why not mount it to the mounting tab right above the ram? It turns with the engine correct? Either way I would not clamp directly to the ram. Any deformation to that ram is asking for a leak.
That housing is so solid that I can't imagine you're going to harm it in any way with a couple band clamps.
Are you making a 2-piece sliding contraption so everything still works when one engine is tilted?
I've never used it, but I think Attwood makes a setup for about $25.
I've heard good things about the EZ Steer many times over the years.
Pighunter
I think you should be connecting to the tiller bracket of the motor (that screw hole above the seastar). Or look at a seastar HO6001 tie bar bracket
That would have probably been the way to go 2 years ago when I first ordered a kit (that never arrived). But anyway I'm going to make up something, I'll post pictures when done. I did attach a bracket to the screw hole above the sea star, but it has a very small clearance and would only turn the motor a few inches before binding.
check around and see if you can find one of these. This was the tie bar bracket off my Yamaha ox66s. idk the part number. I don't think it was a Seastar brand product. Did'nt work well on the suzukis so I trashed it and got an HO6001.
Pighunter
I made a couple of brackets and it seems to be working, I'll water test it next week not the prettiest but oh well
Redneck ingenuity at it's finest!! It looks like it should work. Let us know how sea trial goes.
Pighunter
Lol. I agree, Its working in the driveway, it's only got work thru this salmon season and with any luck I'll be able to find a motor upgrade in the next year or two. Trying to find a motor these days is like hitting the lotto.
Pighunter
WTF?
...Where's the Fish?
Got skunked! (water temp is still to low) But I got boarded by the coast guard, all was good with the inspection except I don't have a anti pollution sticker on my dash. She gave me a written warning, when I asked what it's for she said to remind me not to throw oil in the water.
