- Oct 12, 2017
- Manasquan Inlet NJ
- Website
- www.youtube.com
- Express 265
If you run less than 100hrs a year you are going to do oil change between seasons. This is where it gets you. Say you ran 75 hrs. pull the boat for winter. change oil and "think" you reset the alarm.I'll likely end up changing my oil due to the calendar rather than the hours. Hopefully I can get that alarm to work for my needs.
I am surprised how inconvenient they made it to cancel the oil change notification. I can't help but think a lot of mechanically uninclined Suzuki owners end up heading back home the 1st time that alarm goes off.
25 hours into next season the alarm goes off while you are underway.
The procedure requires you to turn OFF the Key, turn ON the Key, pull the kill switch and press the Start/Stop button(3 times in 10 seconds) for the alarming engine. If you have twins, you need to do the procedure twice. There is one Key and one Kill switch but two Start/Stop buttons.
