Thru Hull transducer
wbdenamur
Panama City Beach,FL
I am looking to place a flush mount Airmar transducer on my Marlin. If I put it on the flat area made for mounting thru Hull transducers, will the fact that it is slightly recessed cause turbulence and poor readings at running speed?
g0tagrip
Indialantic
I have the thru hull transducer on my Marlin on the flat and have never had an issue with turbulence or poor readings unless going in reverse.
Grady fun 5
On my 2012 305 express which is the same hull as your Marlin. I have no issues with Airmar Transducer’s mounted in the factory flats
Dand1
I have them mounted in the flats of my 305 Express ( same hull as Marlin) and they are fine
Good Luck
wbdenamur
It is recessed. The outer edge is even with the hull. The inner edge is almost 2 inches higher thus giving it a 0 degree flat surface but disrupting smooth water flow.
OK. There are some boats/hulls where the area is simply flattened out - but not actually recessed. Defnitely don't want the ducer mounted up inside the "hole".
