- Oct 16, 2007
- Age
- 69
- Cape May, NJ
- Islander
Replacing connectors on my fuel tank sending unit. Factory wiring not tinned copper - raw copper. Keep stripping back and all I get is black wire. Common problem on the GW's. I was able to use a Dremel wire wheel and a block of wood to clean the wire. Strip wire back and use wheel to work away from insulation to clean the wire off. Not a very good photo but the red wire was clean copper (after) and the green wire was black (before). Was able to barrel twist wire, rosin flux and solder.
Connections adhesive shrink tubing and secured. To each his own on soldered connections. I know mine are electrically perfect! If you want to use crimps just clean and tin a small part, strip back again and crimp.
EDIT: 9/3/23 Replaced photo.
