Trying to remove cockpit light panel
quantase
I’m trying to access the starboard tubing that currently supplies antennae cable, so I can drop Garmin radar power/network cables through along with GPS 24xd cable. I want to remove the almond color cockpit light panel from my 2022 grady white 235 hardtop. Anyone know how to remove it so I can snake the cables through the tubing? I tried to use an old credit card and metal spatula to pull it a loose without success. Not certain how the panel is connected to underside of hardtop. Thanks.
Unless you can find someone with first hand knowledge I would call GW Customer Service. At least see who the manufacturer is and get instructions. Also useful if you break it!
My "guess" would be with platsic Christmas trees... but that's just a first guess. What I would do is pop out (down) the lights (they appear to be the kind held in place with a spring clip) and look inside - there's a good chance you can see what you need to see to do what you need to do.
Reactions: Halfhitch
