USB outlet
SCW
Cape Cod
I would like to swap out the cigarette lighter outlets on my 2011 275 Freedom with USB outlets. Has anyone done this? If so any info on the best one to buy and how the install went would be great.
Thanks in advance
Very easy and straight forward install. There is no "best one". But they are easy enough to find as they are very common. A company like Blue Sea is an excellent company, though. Google will be your friend if you want to buy online - otherwise, any marine store can get this for you.
Or, just get an adapter that plugs into the 12V outlet. Again, Google.
Halfhitch
Venice, Florida
Losing the ability to power a handheld light for spotting navigation markers, water hazards and emergency rescue situations would make me hesitant to eliminate the good ol' cigarette lighter socket. For the times you need to charge something onboard why not just keep a couple of these handy?
https://www.westmarine.com/buy/ulti...xl-12v-dual-usb-charger--13845714?recordNum=7
Or install separate USB sockets and leave your OEM sockets in service.
Reactions: suzukidave
suzukidave
this. usb connectors are also going to corrode in salt air. just get a couple of plug in adaptors and use and replace them as needed.
Halfhitch
Venice, Florida
I whole heartily agree with the corrosion factor of the USB connectors. I don't think the adapter should ever be left in the socket either but removed at the end of the trip. I believe if left in they will contaminate the sockets.
Bayhouse
Make you sure get one that puts out high amps for phones or iPads that support or need 'fast charging'. Added one on the inner shell of my helm compartment on the 330 and use if to keep my iPad charged (iNavX for extra navigation).
I mounted a switched dual usb/ 12v. Easy. cheap one's all over amazon and eBay
