- Sep 1, 2013
- Allentown, PA & Friendship, ME
- Offshore
The digital display for the engine trim (little LCD bars that range from 1-5) is acting funky. When trimming the engine through it's full range, the only thing going on with the display is that it "looks" (even if engine is all the way down) like the engine is all the way up and the LCD bar at the top (#5) just blinks. HOWEVER, if I tilt the engine up fully, put the key in the "run" position w/o starting the engine, then manually push the trim sensor through it's range, the gauge works perfectly. I then visually watched as I lowered the engine and the engine does engage the trim sensor arm. I manually operated the trim sensor a number of times and every time the gauge displays the appropriate LCD bars according to where I am holding the sensor arm.
So... if the engine pushes the trim sensor arm the gauge continues to think the engine is up (and the top most LCD bar blinks). If I push the trim sensor arm, the gauge responds just fine. :bang
