- May 4, 2022
- Age
- 41
- Madison, CT
- Express 330
I have an 04 with the sidpower bow thruster. it has a Sleipner SP55 motor on it. I know this SP55 was superceded by a different motor at some point. My care program consists of changing the zinc on the prop every year and never ever ever activating it when the boat is out of the water. Mine has a fluid reservior which I check once a year but haven't had to fill it. someoone told me is lubrication for the gearbox but same person also said newer models don't have it?I have a 2007 330 Express and need to do maintenance on the side-power bow thruster. What anodes and parts need to be replaced?
Is the Q Prop upgrade kit worth it or necessary?
Does anyone know what model came in the the 2007 330? Thanks!
Maybe the change from sidepower to Vetus explains why I have the lube tank and you dont?Got me thinking about mine. This is from my Vetus 4512D Bow Thruster Installation Manual: "The bow thruster tailpiece has long-term lubrication."
Never thought about my thruster. Probably full synthetic lube. As long as you don't chew a seal up with fishing line or shaft crud it will last a long time. Good thing too because you would have to pull the whole unit out top and bottom to check or change.Maybe the change from sidepower to Vetus explains why I have the lube tank and you don't?
