- Oct 16, 2007
- Age
- 72
- Cape May, NJ
- Islander
Drill the hole with a stepped bit. Take the shavings off as you go. You would have to take the sending unit out so blow it out, get a vacuum in there on a piece of copper tubing or PVC pipe.
Stepped bits are the best way to drill holes in plastic. Drill bits and hole saws make a mess and sometimes crack the plastic. I drilled holes for my chum buckets and 5-gallon bucket garden planters. Works great.
Use a piece of butchers twine or electricians pulling tape, pick it up with a vacuum thru sending unit hole. Thread fitting on and pull into place. Put a stop on both sides of the fitting and leave it long in case you have to pull it back out.
