Blaugrana
- Sep 16, 2019
- Age
- 41
- Bayville, New Jersey
- Seafarer
I just completed a similar project over the weekend...
Nice install Don!
I'm torn with making a full panel to cover the whole area, or do as you did with just the area for the display. How much trimming of the old box was required to fit that display?
Timcan,,,, I went from two Carbon 7's to a single Simrad 12 and have been very happy. Can see a split screen and details much better on the 12 than I ever could on the 2 individual screens. No regrets switching to the single unit.
Im debating between two 9s, or 1 12" screen....Your comment has me leaning to the single 12.
My concern is the screen height on the 9s being so similar to the 7's. I feel like I want the height more than the width, allowing to see farther ahead on the chart and more detail in the water column (at the cost of some sonar history). am i crazy?
Nice install Don!
Your welcome, it was tighter at the bottom so I made the cut all out of the top side and left the bottom original...Thank you sir!! Appreciate the picture. Doesn't look too bad of a cut.
I just installed my custom kicker swim platform bracket with an underneath brace. Next I will bolt on a Suzuki 9.9 high thrust. Then make my own steering mechanism attaching the kicker to the main engine.
Nice clean install! Good to know I can fit two GO9s there if I ever need to.I think it’s a preference on how you plan to use it. I just went with two 9s as I wanted to have a full display with side view and the other with some sort of downview. Splitting a 12 would make the side view really narrow.
Take a look at the specs though as I thought some devices let you change how you want to split it, either vertically or horizontally. Also, think about how you plan to use it. The opinion is split, I read a lot on THT before pulling the trigger. No right way.
You should also consider how big the 9s are as the GO9s barely let me install two side by side without cutting anything behind it. I think they have the smallest footprint except possibly for the new Garmin that looks very similar. At some point after 2000, I would not have been so lucky and it would have required more work. Just something else to take into account.
