JUST-IN-TIME said:
2 micron
it comes down to GPH flow
no outboard pulls more than 50GPH
This is simply just not entirely true - I do agree that the no outboard pulls more 50 gph - but it is so much more the rated GPH flow-
From memory, the 2 microns are rated 1.7psi pressure loss @ 15 gph flow - basically this is just a point on the pressure/flow curve. The pressure/flow response is close to linear - in other words - they could rate that same 2 micron filter at 3.4psi pressure loss @ 30 gph-
The key here is not the flow rating of gph, but to make sure that your system has reserve pressure capacity to move the fuel thru the system at the new system pressures -
What I am really not sure about is if the VST pump could be damaged over time- it may not be a problem at all, especially if the 10 micron in a dirty state induces 5 or 10 psi into the system - I just am waving the flag of caution on this -
