2024 Marlin Trim Tabs
Motivator
What's up with tabs on the Marlin? Some ad pics are showing them in a pocket while others show them mounted to the transom.
drbatts
CT
Every marlin I have looked at has had the tabs flush to the transom and the actuator in a recessed pocket. Most of these boats were 2000 models on. Maybe the older ones had them on the transom?
Poolmaker
Neptune Beach, FL
The pre 98' hulls had them in a pocket forward of the transom at the front of the step. Every other later model I've seen has been as described above.
family affair
Ohio
All boats were listed as 2024's and still on the dealer's lots.
That is odd. I thought GW typically hid tabs under the hull to avoid having under water protrusions. Looks like they changed at some point in 24. Making room or cutting cost?
Mine are in pockets. I think they all have been for many years.
looks like the F350s have them off the transom. My guess is they work better there. Another reason to go with the F300.
Sardinia306Canyon
Island of Sardinia
That's wired:
1 x F300 trim tabs in pockets
1 x F300 trim tabs on transom
1 x F350 trim tabs on transom
Could it be that GW use the same hull for another model (Freedom or Canyon) and just install another Deck on same hull?
To make two hull moulds for one model with the only difference of the trim tab pockets sounds a bit extreme to me.
Chris
drbatts
CT
With the trim tabs off the transom, won't the swim ladder hit the starboard tab?
family affair
Ohio
That's wired:
Chris
Good call. Does the same Canyon or Freedom 30' have exposed tabs?
Possibly the case, but I would be surprised that fiberglass molds could be that precise to allow interchangeability between caps.
family affair
Ohio
Here's one for the conspiracy crowd: New f350s are so light that there was a need to change the boats CG for better handling so they went to a different hull mold that moved weight aft.?
Looks like the 306 has some with and without pockets too for 2024, but 2025s have no pockets. It looks like the contour at the transom is slightly different too:
