222 fisherman issues
jbukie said:
jaydub - You see water coming in through the deck drains or in the engine well? or both?
Usually just the deck scuppers, but nothing like you are describing. You can get water in through the engine well drains but it usually is only when you are in rough water, you get a boat wake, or running in reverse against chop. Water stays in the engine well and immediately drains out like it is supposed to. Mine is a 250 so it is a bit heavier than the 225 too.
What you are describing does not sound normal. Did you look in the bilge to make sure there wasn't water in there or the livewell or washdown pump weren't pumping into the bilge? That would add a lot of weight especially if the bilge pump wasn't working or couldn't keep up. Something sounds peculiar so you are right in being concerned.
