268 Islander Fuel Tank Replacement
where did you get the hdpe blocks and how did you secure them to the stringers such that they will hold the tank down with no movement in rough conditions?
In theory, your boat is tilted bow high and has drained out.
Its not a water pipe full of water. No water to expand when it freezes to crack it.
You plug the fwd to aft pipe? You rely on the fwd bilge pump to clear the bow? I don't like that...
I have no plugs. Any water drains aft on plane. Some sits in fwd when at rest but pumps when the fwd float switch kicks.
Problem I had on my old V20 was that decades of crap was blocking up the front end of the pipe, slowing down the flow, and there was no access to it without cutting the floor of the fishbox
A garden hose to the aft end would clear it for a while. Anything that goes into the cuddy deck drain is there forever. In the V20, the fishbox drained to that space. Think Striper scales....and everything they puke up... I ended up using that space for storage. removed the bottom and added a second bilge pump there.
I think a lot of old boats have that problem. Many boats have the same "pipe under the tank space" configuration.
My 265 has acces to the front of the pipe in the cuddy. There is a fwd bilge pump and also a shower sump.
You can't really access the forward end of the 1/2" pvc. It's under a glassed-in shelf for the shower sump. It is plugged in the aft bilge. In my case it is unlikely it will drain in the winter.
The HDPE blocks are GW factory. Philips head wood screws were replaced with Simson Torx head stainless wood screws.
We just pulled both tanks on our boat, following your process.
Looking good. I took the bulkhead completely out - right to the stringers. Took the tops off side boards, cleaned some foam out and installed one piece of 3/4" Coosa board. Used West 610 to task in and then glassed it in. You need a 1'x1' cutout like the step to get to the fuel fills - easy access and easy repair like the step. Make cuts on flat surface not curved.
Glassed in new stringers, while we were at it..
Glassed the step back in.
Was able to bevel from the backside and glass it in. Rock solid after 3 layers of 1708 and west epoxy.
Thanks again Frank for the documentation.
You definitely helped make it less daunting.
Reactions: family affair
