282 Sailfish Thru-Hull Transducer Help
vinpaa
Babylon NY
Finally got mine finished and seatrialed. I put it right where you were thinking between the flat spot and the stringer. It fits and works flawlessly.
Jdrurb, looks good. I ended up getting mine installed by a local outfit. They installed it behind the pockets, accessing the area through the transom access ports. Dropping her in this week, haven't sea trialed her yet.
Reactions: Sharkbait282
Sharkbait282
Newport, RI
This is where my 20 degree B164 is located on a 2002 282 Sailfish, once your settings are dialed in you should have good results. I hold bottom to several hundred feet at least (haven't gone further than that yet) at 30+ knots of boat speed.
vinpaa
Babylon NY
Ran the boat for the first time this weekend with the new transducer. Held bottom up to 40knts. Very happy with the outcome.
