That is s sharp looking install. If you have the chance would you be able to give more info on how you did it? Thanks in advance!I have an 2001, I was able to do the starboard side myself along with new thru hulls. I have not done the starboard side yet. Probably put in an access plate. Then I would be able to access it.
I did add hot and cold shower to the Transom, thats very nice to have .View attachment 25978
I didn't realize one was a mixer and the other, the shower head (I thought it was 2 shower heads). That is a nice set up and one I will likely copy. Did you have enough with the drop in box just in front of that? How much depth do they take up? I would prefer to keep by ladder/transom door.I used Scandvik products because thats what Grady uses, When I do an upgrade I try to make it look original. I opened up the panel in the aft cabin on the Starboard side. All I did was tee into a hot water line and a cold one(barbed plastic tees and clamps), ran the hoses to the transom and behind the generator, up and above the batteries is where I mounted the mixing valve and the shower wand.
Links for both below
It is great to have it there, we stay on a ball in Block Island and we all shower out there, not to make a mess inside.
Scandvik, Inc. Marine, RV, Boat, Boating, Yacht, Nautical Supplies
<p>Scandvik, a marine supply company with more than 35 years of excellence supplying boat builders and distributors. Faucets, Sinks, Drains, LED Lighting, Electric Table and Seat Pedestals, Linear Actuators, ABA Hose Clamps, Dolphin Battery Chargers, Teak Wonder, Hot Wave Water Heater, Door...www.scandvik.com
