gw204
cdwood said:Ok, just wanted to clarify. If you look closely at the pics of both sheets you can see that there is a 4 inch difference in the cuts and they were cut at a 45 degree angle. Will try to post some better pics.
Focus is not real good on these shots, but please look close. Is this what you meant?
Yep. That's the general idea.
However, instead of cutting the ply at 45 degrees, I would have used the grinder and tapered the pieces back about 6 inches. That would have given you an 8:1 scarf (bevel back 8 inches for every 1 inch of thickness). The farther back you bevel, the stronger the joint. Does that make sense?
I don't think you're going to have any issues though. The 45 degree cuts and 4 inch difference in placement should be good enough.
Nice job!
