A/C in a cuddy cabin
family affair
Ohio
The unit itself has some potential. You'll need a lot of lipo to make that work off a battery.
What brand?
wahoo33417
West Palm Beach, FL
Nice find. I'll echo Family Affair and ask what brand?
I wouldn't expect 2500 btu's to do much during the day, but may do the job after sundown.
Keep us posted.
greauxpete
Tha Bayou (Youngsville, LA)
Family/Wahoo,
I found it on alibaba:
https://m.alibaba.com/x/AxEWUb?ck=pdp
I could not find a unit with this cooling capacity for under $600, so I took a gamble. The unit came damaged but I managed to fix it and it functions. I may return it if it does not cool off the cuddy at night during the summer.
It definitely won't make a dent during the day, my intent is to use it after dark only.
family affair
Ohio
So is the price shown on the link correct?
I see wally world has a 5k BTU that is about 35 lbs and 45bd for under $200. Ive wondered if I could make a platform for the walk around to blow it into the port cabin window.
My wife and I have a few more years before overnighting will be a more common option, so I haven't attempted it yet. But you can! :)
wahoo33417
West Palm Beach, FL
Greauxpete: In case your unit doesn't work out the way you hope. I'll offer an 'off-the-wall' idea. I'm good at those ;).
I saw in Home Depot what struck me as one of the smallest window AC units I've seen. It was a Toshiba offered in both 5,000 and 6,000 btu's at same dimensions, similar weights and prices.
Here are specs:
IF it fits in your fridge space, then would need to solve where it draws air from. Ideally, you want it to draw air from the cabin as far from the intake as you can.
But I suspect the area behind your fridge could draw air all the way to your head holding tank and maybe even gas tank. So the challenge would be if those areas can largely be cut off from circulation. If so, then you just need an intake vent to the area behind the fridge.
And you may need a condensation tray that drains to the bilge or to the shower sump.
Like I said, and off-the-wall idea. A lot more work, but a lot more cooling power.
Since its 110 volt, could install a 100 receptacle below the helm. It has the male end facing outside and a short female end on the inside of the bulkhead.
Reactions: airmanjun10
