I'm trying to run down an issue with my FP diesel genset. I'm looking to find where the AC control box was installed on a 2007 Marlin. I don't recall seeing it. I'd like to check the capacitors.
My issue was starting a Genset after it sat so long while work was done on the boat. The panel lit up and I pressed start after turning on cooling water. The genset turned over a time or 2 but then the panel went dark. I checked the 25amp blade fuse and it was burnt out. I used power to activate the relays and then clicked, and when powered I had continuity on the other 2 blades. I think the relays are OK.
I'm replacing the fuel pump as it was severely corroded, I'm guessing the genetic didn't receive a signal from the fuel pump and shut down.
However, the panel refuses to light up at all after replacing the 25A fuse and checking the K1 & K3 relays.
So the original question, where is the AC control box installed on a 2007 Marlin?
