- Sep 1, 2013
- Allentown, PA & Friendship, ME
- Offshore
Looks like you're on top of things.
Here's a thought... and I don't think this would really cost all that much at a local welder...
-- Weld a some tabs - say 3 on each of the long sides - so they stick up enough to allow for a hole where you could use a screw to secure the tabs to the stringers (and use blocking in between the tab and the stringer). Make the whole quite a bit bigger than the screw to allow for expansion/contraction/vibration/movement.
Or, along the same idea, get two lengths of aluminum angle iron an use 5200 to glue them to the edges of each of the long side. The do the same thing of screwing to the stringer. You'd have the entire length of the angle iron glued to the top of the tank - I have no doubt that would be a permanent attachment, espeically if you lightly sand the contact points.
For the tank to floor issue you mentioned... maybe it would be easier to address this by modding the FLOOR as opposed to trying to adding things to the bottom of the tank?
Either way, if you haven't already thought of it, make a quick "profile" of the tank shape with a piece of plywood. Basically, trace one end of the tank onto a piece of plywood and cut it out - now you have a perfect representation of the tank bottom's shape and can use that to better fit support needed (whether on the tank or by modding the floor).
