- Sep 1, 2013
- Allentown, PA & Friendship, ME
- Offshore
I was thinking more about the OP's hatch in my response.THanks, Dennis. The hatch itself is fine. There’s no bad core. The only damage is what’s shown in the photos above, and it doesn't extend past where the gelcoat is chipped. I may just apply the epoxy to the back side for strength and Spectrum color get coat to the front side, and with a little heat that may be all I need. From what I recall, West System mixes up pretty thin by itself without adding any thickeners, so I may not need to do anything.
The existing gel coat on the outside edge is probably 10 or 11 mils thick, so I think my biggest concern is getting a good bond with the resin underneath so it doesn't flake off.
But looking at your pictures, one thing I notice right away is how crisp the bottom edge is. Hard/crisp edges like that tend to make chipping like you have even more likely. That bottom edge should be slightly rounded.
You'll need to (best practice) grind away some of the gelcoat where the chipping stops. This is to ensure that there's nothing loose there and also for better adhesion in the repair.
